patio question
10 Feb 2014
Oxfordshire
Was planning to lay my patio very simply in a square stack bond layout with the 45cm square slabs that I already have, but having measured up I don't have enough. Been trying to find some matching ones from gumtree etc, but no joy so far.
Its now got me thinking that maybe I should add some block pavers in between to make the pattern more interesting instead of trying to find matching slabs.
My question is, does this make it much more difficult? I've never done anything like this before so wanted to keep it as simple as possible!
Cheers!
How much are you short? Adding bricks or contrasting slabs to make a pattern or a border is a good wheeze.
You say you can't find matching - do you mean colour and finish, or size? If only size, you can mix them up and end up a few small unfilled gaps.
Which brings me back to how much are you short? If not a massive amount you could consider leaving gaps to make up the difference and plant thyme, or chamomile etc - looks good, and smells nice when walked on.
https://joansbolton.wordpress.com/2011/03/24/mind-the-gap-planting-between-pavers/
I was going to suggest an idea (which would require the hire of a saw) of cutting some on an angle so that you could let in an asymmetric line of bricks, other pavers, decking, gravel, resin-bonded gravel or glass, whatever - don't know if that would have bought you enough coverage though.
