Water can be dosed with whatever you like.
Copper is not chewed by rodents!
Copper withstands at least 250 C ( which melts the joint solder ).
Copper does not sag.
Copper can be removed and reused elsewhere.
Copper has a scrap value which can be reclaimed at any time in the future.
Tony,
Both products have their merits, all visible pipework in my own house is copper, radiator tails, boiler and cylinder cupboard etc.
Water can be dosed with whatever you like. - yes you can, you can also dose plastic within the guidelines.
Copper is not chewed by rodents! - Rodents also will chew through electric cables etc, there is nothing in the material that attracts them. If there is a big rodent problem I would a) use copper and b) advise them to get Rentokill in.
Copper withstands at least 250 C ( which melts the joint solder ). - Plastic has it's limitations and has strict guidelines where it shouldn't be used (gas, oil, compressed air, steam) and is ok up to a short malfunction temperature of 118 deg c at 3 bar. Seeing some boilers are set at 82 deg c max (condensing boilers less) temperature shouldn't be an issue.
Copper does not sag. - if surface fixed use copper or trunking.
Copper can be removed and reused elsewhere. - So can plastic
Copper has a scrap value which can be reclaimed at any time in the future. - Exactly but not always by legit persons, metal thefts are a major problem
