PCB plug advice needed
23 Mar 2021
Good evening , hope you are all well, I'm trying to purchase some small plugs to attach wires to a PCB , shops dont stock them and I've already ordered the wrong ones , please see the attached image , can someone please tell me how you measure these so I can ordered replacements , what am I measuring ? , the actual metal part on the crimps on mine ( plugs) are about 6mm , however all of the ones that I see for sale are smaller , I need the plugs rather than the pins , is it the pins on the board that I'm measuring in order to determine the size of the crimps needed ? , any help would be appreciated, Thank you
I suspect one need pictures of the PCB (with a scale alongside) and or the PCB ID numbers.
Pin diameter and length and spacing will be critical, usually.
CPC Farnell and RS Components might stock a range that could fit?
