Peraring for exterior paInting
6 Feb 2010
Carmarthenshire
Hiya, i'm planning on painting the exterior walls of my house over the next few weekends (inbetween six nations games).
The walls are smooth rendered and have never been painted, i've raked out and filled all cracks last summer, are there any suggestions on priming the walls before painting?
I was going to use diluted builders pva.. If so any sugestions on how long it takes to dry?? Also is there a problem if the temperature outside is around 6 - 8c? The paint i've bought is Sandtex fine textured masonary paint. Thanks for any comments
Too early yet for exterior emulsion really.. If the wall is dry and not flaking then only a dilute coat of emulsion is needed to start you off. Do not use PVA before emulsion paint. If it is flaking or sandy then use a stabilising solution.
Ok cheers.
Whats the reason for not using pva? Would it stop the wall breathing? Or wouldn't the paint take properly to it?
There seems to be lots of people, mainly on tv that think PVA is a good sealer/ primer for emulsion, but it doesnt work like that. The emulsion will probably peel off later.
another good tip is to go over the wall with a stiff broom head, to get rid of any dust etc that may be resident on the exterior wall surface.
If you want a good finished job, preparation is the key. :D
