So I have a glow worm energy 25r. Fitted about 13
Months ago, so due it’s first service.
However in typical fashion, got a couple of errors today! First was just an ‘error’ I restarted and it disappeared, however this evening it displayed f28 error, restarted and ok again.
not sure if related, but I’ve noticed recently that the hot water in the kitchen takes longer to reach the tap, and when it does, the pressure seems less (we have a hot water tank and gravity fed system), with the hot water running if you turn on the cold, you lose the hot water (normally the temperature would gradually lower).
Would a blockage somewhere cause both issues?!
Should add that it heats the radiators and a hot water tank. If that helps
