just wondering. did a few landlords on performas 24he combi. noticed with a few that the hot water cuts out for about 3 sec every minute or so. has anyone come across this before?seen about 6 like this so far.
Does it go up to 80 on the red lights before it cuts off, if so plate heat exchanger scaled or sensor, if it does it more rapidly its the sensor.
As dave says check the pressures to make sure its not set below what the minimum should be
