Hello,
I have a Potterton Performa 28.
The hot water works perfectly. The problem I have is with the central heating, it does not circulate the heated water. When I switch the CH on the temp increases to 80 degrees in about 20 seconds and then cuts the boiler out for a couple of mins, it then restarts with the same problem.
The CH flow pipe heats up but it seems the return is not working.
I checked the pump via the vent screw with a screwdriver and stopped the pump without much force. I have replaced the pump with a new one but still have the same problem.
Could it be the PCB?
Can anyone please shed some light.
