Permanent radiator removal
8 Jul 2007
Yorkshire
I need to premanently remove a small radiator in my kitchen, which is on an open vented system. I undertsand that with the pump switched of then the pressure is standard atmospheric pressure, which means that I could technically hold back the pressure with my hand.
If so, (and I don't mind getting a little wet) can I cut the pipe and end cap it without draining the system?
doubtfull, the water will want to rush out as sonn as you cut through the pipe. you may be able to put a bung in your loft tank though
Aerosol freeze kits work if you cant be arsed draining down
Snatching it is possible but i wouldn't risk it unless maybe under floor better to bung it or drain it
Go on, do it!. Get someone to video it, upload it and the post back with a link..... In need of a laugh today :wink:
Go 4 it son keep a couple o carrots handy 4 when your fingers go numb 2 stick in pipe .
No seriously stick 1 in your vent pipe (no comments please)and other in tank outlet then go 4 it afterwards use em to make a pat o soup. Omake sure you dont ram em in too tight or you gonny spend rest o sunday howking em out.
