Works well until you need a working phone to call the electricity company to report a power failure..........to get a digital one that just requires a base unit connected to a line and the rest run wireless.
Hey smarter than the average sheepdog. I don't have stairs in my bungalow.mwatsonxx.244747 you know what to do then, like everyone else does, use your original phone that does not need the mains (it's in the cupboard under the stairs) or your mobile until things are corrected just like the rest of us would do.
Difficult isn't it!
Thanks for your detailed and comprehensive reply. I'll go hunting for the last extension socket and start from there, thanks again.To answer the original question........
Although you can splice into a telephone cable which is serving extension sockets (not the incoming cable going to the master socket - this is owned by Openreach) you are better off making the connection at an existing outlet, bearing in mind that normally a maximum of two cables may be put into an IDC connector. If you need to connect in a third cable, you are better off using 3-way gel connectors (search "gel crimps" on e-bay) to avoid potentially damaging the IDC (insulation displacement connector) on the slave socket. If you have no alternative but to splice in to an existing cable, then use a connector box (search ebay for "telephone junction box"). Don't scrimp on the cable, use good quality 100% copper CW1308 cable, avoid the copper clad aluminium cable which is much cheaper, but FAR less reliable!
HTH
Telephone faults, Broadband speed issues, master sockets moved. Specifically telephone and broadband specialists
0203 633 1131
