Phone stopped working, just a continuos tone, now fixed.
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
Daughter told me phones not working, we had got a new Sky router in the post, but to fit it would mean the name would change, and every device would need re-connecting.
So I was not keen on swapping the routers, however when I compared old to new, they looked exactly the same, so unplugged phones from wall and plugged into router instead, and they work.
But now, if I unplug the router, my phone will not work, that does not seem a very good idea.
If you set the wifi SSID name and password the same as the previous router then all devices should still connect.
I had considered that, but new router and old router look identical, so can't see any reason to change them?
The old router had a slot for a phone, just not used, so moving phone lead from wall socket to router got the phone working again, but now phone stops working in a power cut.
PTSN is being turned off in January. Once the transition is complete, I believe, that no landline will work in the event of a power cut given that they will all be connected to the router and become VOIP. That said, I can't see how that will work for people without a router. Hopefully, some one who knows more will chip in.
Edit- more info here
It is the responsibility of the communications provider to ensure those who depend on a landline are provided a resilient solution that will allow customers to make calls to the emergency services in the event of a power outage and the government is working with Ofcom to ensure this is the case.
For most customers, telecoms companies recommend using a mobile phone as a backup in case of a power cut.
From @opps link.
My mobile I suppose is now the back-up system, it does work in this house, except when we had a storm a year or so back, when it failed, causing the geo-fencing on the central heating to think we were not home, and turning the heating down.
I see a lot of hype lately about PMR466, but mine have tone squelch so would need that removing to use like a CB, the 2 meter repeated is out of range, don't know of any 70 cm, so only the local railways own repeater which is illegal for me to use, serves this area. In a real emergancy I am sure no one would mind me using it, but only listened to when railway is running.
Not tried CB, used it years ago, and got some hand sets some where, maybe time to dust them off?
But likely too late when we do lose power, so time to talk about it is now, I play games on my phone, and so does my wife, so often the phones are down to a very low battery state, the same applies to the main battery for the house, it is not used solely for power cuts, so it may be down to 10% when we get a power cut.
So the question is, if we can rely on the mobile phone? The mobile phone has resulted in the demise of organisations like RAYNET so the Rhyl floods today would be very different.
I use to have a ruck sack with radios, amplifiers, batteries etc, all ready to spring into action, alas no longer, batteries not been charged in years. Down to one duel band 2 meter/70 cm with one small battery, and a pair of PMR466 radios.
No longer have the old trusted 290 set up in the car, maybe that should be next project, at least I think I still have a licence.
They will get (or more likely have already been given) a box which is effectively a router without Internet access to plug the phone into.
Or the equivalent of that is installed in the street cabinet, the copper to the exchange is severed and just the small section from the cabinet to the property remains.
Either way, 99% of it has already been done. It is just a tiny minority of homes remaining, plus a selection of other lines which were or might possibly still be used for ancient alarm equipment that probably doesn't work, lift emergency call systems which haven't been serviced in years and other obsolete junk that should have been replaced over a decade ago. Plus a fair number which are redundant but are still being paid for because no one at the company paying for them knows what they are for.
The reason to change them is to set the new router wifi SSID and password to the same as the old one so that all your existing devices think that the new router is the same as the old one.
Otherwise you have to go round each device and reconnect it to the new wifi.
It seems Sky rang yesterday, but I did not get to the phone in time, can't work out why they have sent me a router which looks exactly the same as the old one.
All I have done is unplug phone from normal socket, and plug it into router instead, new router still in its box. And all seems to work, except with a power cut.
Otherwise you have to go round each device and reconnect it to the new Wi-Fi
DECT for cordless phones not Wi-Fi, it's a different band and signalling format see https://www.gigaset.com/hq_en/cms/dect.html.
One can only presume that your phone connection was converted to a digital format only, especially as there a new router supplied. Was a series of letters received advising you of the change which have been ignored, perchance? Be pleased if the original phone number is retained. The system is known as Digital Voice on BT/OR network.
If the router was connected to the 'old' copper wire system (a.k.a. ADSL) presently (I presume) you now on FTTC system; the conversion to FTTP will come along in the not to distant future.
