Physics question...
the smallest possible unit of time in which we can record an event is the Planck Time, 0.539 E-43 seconds. This is the shortest amount of time a particle interaction can take place. To be any shorter, the two particles woudl have to be closer, and then the woudl become indeterminate from one another. This still may not be the shortest interval of discrete time.
Are you suggesting then that the ball remains stationary for one planck unit?
if the motion of the ball is continuous, then the Planck time and the Planck length are the shortest possible time and distance it can stop and reverse direction
The Heisenberg Uncertainty Principle states that you the act of observing affects the observation at a quantum level. hence you can determine the velocity of an electron but not its position, or you can determine the postion of an electron but not ist velocity.
Sorry - no offence but I'm struggling with this due to the typos. I'll research and get back to you.
If there is a point where the ball is stationary, it must occur at a point where its direction reverses in less than the Planck length, in less than the Planck time. we cannot determine at that moment both the position of the ball and the velocity of the ball. Hence we wouldn't be able to determine if it stops or instantly reverses direction.
Does this not contradict the definition of a planck unit?
not at all, the Plank units are the smallest units of distance and time WE we can observe, but there may be units of time that are shorter and distances that are shorter. we dont know. If Roger Penroses Twistor theroy is correct , then there are smaller units than these, but the dimensionality of space time breaks down. If thats the case we wont be able determine motion changes in 3 dimensions in a 2 dimensional space anyway.
In any case, we as humans, even the sharpest of us, cant perceive any event shorter than about 100 milliseconds, and the ball most certainly doesnt stop for that long.
Perception isn't relevant, surely. It's what a physical (quantum) limit is that counts :confused:
its all to do with the amount of time it takes external data to travel up your nerves, processed by your brain, and your internal mental model of the world to modify using hte new data. This is another debate - your perception of 'now' is actually about 200 milliseconds behind whats actually going on. So the scales in which the ball MIGHT be stationary ( 0.539 x E-43 are 41 orders of magnitude faster than we can perceive.
I beg to differ.- if a rocket's engine hasn't created enough force (propulsion) to overcome the force of gravity, then the rocket will not leave the ground. The analogy with the above holds
It does depend on relative density, and my uncle's thick as firk! :LOL:
BUT....the time it is stationary is so small, and unmeasurable, it cannot be determined.
We seem to have determined it to be either zero (it time is continuous) or 1 planck (if time is discrete, but also continuous :eek: :confused: )
yes, pretty much so.
but if its less than the Planck time, we cant measure it for all sorts of reasons.
Nah its a schoolboy simplification of the problem, its accurate enough for A Levels and thats about it.
Bit of a harsh precis of some newtonian mechanics :LOL: :LOL:
Anyway, the formula referred to relates to the energy changes (as it's based on the relationship between kinetic and potential energy), which is surely part of quantum physics :idea:
yea but Newton was a bit slapdash with his theories, thats why Einstein and Hawking had to improve them. :LOL:
Him and Margaret Thatcher was Granthams contribution to UK history.........
So if it cant be measured ...........There is no conclusive answer...?????????????
There COULD be a point at which the ball is 'stationary'........
(my coats already on)..... :LOL:
is that not relative to the puzzle, the ball will stop when it reaches zero velocity, for how long god knows.
Well, not exactly, or then again maybe.
That v^2 = u^2 + 2as formula.
Shove an "m" before anything and divide everything by 2 gives you the energy change "rule" ( with "0.5mv^2" being kinetic energy, and "mgh" being potential energy)
Thus :
Final energy = initial energy + potential energy
