It only ocupies one paragraph of bs7671 and is not present on any of the example diagrams.
What I interpret was the intent of the group that included it in the paragraph was in the context of for example a flat with shared heating pipes from a common boiler room. Just as you would main bond the services entering the flat you would bond heating pipes entering the flat, in the same way as you would bond structural metal parts.
Heating pipes which originate within the equipotential zone and are not in a special location should not be bonded any more than a kitchen sink within the confines of 16th edition.
Many electricians still work to the standards of 15th edition which is one reason for confusion, another is unhelpful misinformation leaflets like that linked from Worcester.
Hi i got a problem with my valliant bolier. underneath where it has been earthed from one pipe going to the rest,,, i touched it with wire mash and for some reason the earth wire from where it is connected to the pipe it had a mini explosion or some kind of spark and then my bolier switched of completely. i checked the fuse on the spur switch but it is perfectly fine, i couldnt see a problem with the earthing allthough it sparked so what should i do to resolve the problem ??????????????????????????????????????? i would reallly REALLY APRICEATE SOME HELP !!!!!! please SOMONE HELP !!!!!!!!!
