Pilot cutting out on Baxi Boston 2 floor standing Boiler
31 Mar 2010
Newcastle upon Tyne
Noticed that the water wasn't heating after checking, saw the pilot light had gone out. We relit it, it went for 5 minutes and cut out again. We had a gas registered fitter come and check it, he said it was the pump so we bought a new pump which he fitted. This was Monday, Wednesday went to reheat the water, pilot out again. Can't get the guy back as he was going into hospital. Any advice as to what it could be before we ring another gas fitter?
Pilot outage is, more often than not, caused by a gas issue. You are unlikely to get any advice on here about gas issues.
Pump causing pilot out on a boston not a cat in hells chance.
Advice is ring another fitter who will then look at pilot being dirty , t/couple or gas valve in that order
I think you're really lucky the chancer can't come back.
The pump has got to be just about the only part not to change.
Can't be t/couple or it wouldn't relight.
Later Bostons a interrupter, basic stuff. Check stat, wiring, flue pull, scummy pilot etc etc... Any Gas Engineer should know this.
I miss basic boilers.
I'm trying to picture a Boston, haven't seen one in a while now, can't remember if the stat is a flue or overheat stat :roll:
I'm going to have to check the laptop now :lol:
I am not telling the OP what to do but its almost certain that a millevoltmeter will be needed to diagnose the fault.
Surprisingly few engineers seem very knowledgeable about how to do that.
Dia it would not be the first t/couple that is on its way out and holds for a few minutes before it finally goes or is even just loose
Many thanks guys. I'll let you know what the 'new' gas fitter diagnoses. Annoying to think it's all been a waste of money, and yes the original gas fitter is registered. As an aside, we've had the boiler since 1999 and this is the first time we've had a problem. It was serviced in May and given we haven't been using it much, can't help but wonder if there's a link.
You may have had it since 1999 but I don't think it was new then!
I doubt there was any connection between service and current problem. I expect its age related!
Boston 2 s where still about till after 2000 but stopped by 2005
