I am about to build a new house and I will need to run a water supply pipe about 140 metres (uphill) from the water main at the bottom of the hill to the house. There is a house next door to the building plot and the guy there reckons that he gets about 3 bar from his supply pipe that runs a similar route.
My question is, should I run the supply pipe in 25mm or 32mm? The local utility (Scottish Water) specifies a minimum of 25mm. The house will be a decent size with several bathrooms, all fed from mains cold and an unvented hot water system.
Given the cost of digging up the field etc, the additional cost of 32mm over 25mm is very small. Are there any disadvantages in going for the larger size?
AA
AA
