I am planning to re-plumb my house going back to the traditional tank in the loft system. The bathroom pipe work will be mostly 22mm Polybutylene. I am considering whether I should use a larger diameter pipe from the cold tank in the loft as far as the upstairs bathroom. The hot tank will be directly below the bathroom so this pipe will be refilling the hot tank as well as supplying the cold water to the shower. What do you think; should I go up a size?
