Pipe size to shower size question
15 Feb 2009
Norfolkshire
Hi, i'm in a bungalow with a vented gravity system & showers weren't the greatest, so we upgraded the main to a 25mm & fitted a pressurised system with 4.4bar incoming & 3 bar reduced at the hot water tank has really improved things. On one shower we had hot & cold 22mm incoming & a 15mm down to a pump under the bath & back up to a shower outlet & when the pressurised system was fitted we just bridged the 15mm where the pump was under the bath..
Question is: will it make a lot of difference changing the 15mm pipe to 22mm on the shower outlet. ??? Thanks
Sounds like you have made a good upgrade.
Short answer: no
Flow rate is more important than pressure for this but for that short distance it won't make any noticeable difference
What size are the waterways in the shower valve? Gives you a clue as they are usually miniscule! ;)
