Several times over the years I've heard plumbers max reference to using larger pipes for better flow rates - running 22mm to the bathroom tap, for example. While I can accept that a larger pipe has a greater volume per surface area of internal bore (the inner surface being where friction/resistance to flow comes from) I'm not convinced that using a larger pipe (particularly for hot) gives you better performance, because the outlet is only going to have a certain size and all a larger pipe is going to do is give a larger standing volume of water that must be discharged through the outlet
In the case of hot water (not on a continually pumped circuit) there could be quite a considerable volume to get rid of - by my reckoning 10 metres of 22m pipe has nearly 4 litres of water in it - and that's not very eco friendly..
So when I'm looking at a quote saying 22mm copper for highest flow rates surely this is nonsense (aside from larger pipes having slower flow) and I should be saying to the plumber to use a smaller bore, or even plastic (lower friction, fewer elbows) or I should be finding another plumber who can accurately justify every pipe choice in terms of material and bore depending on the application?
