Hi There
Nice to meet everyone.
I am busy with a DIY project building a Dome. To build my dome, I am using a pipe that is centered onto a board. Attached to the pipe is a spinner with a wood cut out to the shape of half a Dome. This wood is my guide and helps me make my dome uniformly.
My dilemma at this stage is to follow and I require some advice. My Pipe is 2” in diameter. I can’t seem to find a way to create a contraption which will fit onto my pipe and onto this contraption will have my wood attached. The contraption will be at a fixed height on my pipe and should be able to spin 360 Degrees around. After I do a complete 360 degree spin on my dome, I will move the contraption up a few inches and should be able to spin once again, at 360 degrees around. Again, the contraption will be moved up yet another inch or 2 and should once again be able to spin 360 degrees. Basically, what I am trying to say is that I should have the flexibility of moving the contraption attached to my wood (Wood Spinner) up or down my pipe at any height I wish.
View media item 20150
I have attached a picture I found after scouring the internet. The picture is the very similar thing I require, but the picture seems to have a much smaller pipe than I wish to use. I couldn’t get more info on the contraption that was used. I have also added a small description of what I’ve explained above to the picture to make things more understandable.
If you require any further clarification, please don’t hesitate to ask.
Regards
Woodee
Regards
Woodee
