hi i have ahot and cold water pipe that i no longer need i would like to cut these pipes and put end caps on , i dont want to solder the ends on is there any other way i can do this.many thanks
antwill
Ideally you could do with tracing these pipes back and cutting them as close as possible to where they are teed off if they are long lengths so not to leave any dead legs. Pipe cutter and adjustables should do the job.
Yes i agree with terrydoh, to be fair there arn't many more options if you do not want to solder. As already said pipe cutter and adjustables for compression, pipe cutter for push fit
