pipes
5 Feb 2008
hi i have ahot and cold water pipe that i no longer need i would like to cut these pipes and put end caps on , i dont want to solder the ends on is there any other way i can do this.many thanks
antwill
hi terrydoh, is this an easy solution to do do i need any special tools to do this. cheers
Ideally you could do with tracing these pipes back and cutting them as close as possible to where they are teed off if they are long lengths so not to leave any dead legs. Pipe cutter and adjustables should do the job.
hi armo, thanks for the reply,do you agree with terry doh and to use compression or push fit caps. many thanks
antwill
hi terrydoh, sorry for the ignorance but how do i fit the end caps.
many thanks
antwill
You will obviously have to isolate and drain the water from the pipes.
Tracing them back is a great idea, if you can.
Put something under the pipes to catch anything left in the pipe
Cut with a pipe cutter and then slip the fitting on and tighten, holding a nut in one spanner and the cap in the other.
Do not murder them, just get them nice and tight
You need to compress the olive to make a joint, if you murder them they may weep, as it would be a poor joint
Yes i agree with terrydoh, to be fair there arn't many more options if you do not want to solder. As already said pipe cutter and adjustables for compression, pipe cutter for push fit
