Is anyone able to detail what tests are performed in a PIR, or have a link to some more info?
eg earth loop impedance testing
Why?
I would love to know how you carry out some of the above tests without dismantling the installation - which you should not do when carrying out a Periodic Inspection and Report.It would be hell of a post to cover everything, so, a very quick run through, Ze, PSSC, PFC at the consumer unit, R1+R2 of each circuit, insulation resistance of either each circuit individually or the whole installation in one go, ring circuit continuity for any ring circuits, then max Zs for each circuit, plus of course checking for main bonding, labelling, correct protective devices, testing of any RCDs (7 tests for each), these aren't in the right order, think that's about it though!
my usuall one is "which dopey t##t did this?, only to find it was the customer![]()
Which part of Cumbria are you from?
I'm at Ulverston
Mind you (and IMHO) anyone doing PIRs should have a very well-thumbed copy of GN3 on the bedside table.
