As part of a home renovation, I have a solid wall around 6-8m long currently still brick faced and not rendered.
I’ll probably have a electrical socket 2m from floor level in the centre of the wall to power a wall hung TV.
More than likely there will be 400-600mm depth fitted cupboards or drawers fronting that wall with 3-4 double sockets at normal socket height on that wall inside the cupboards for A/V equipment etc.
my question is: do you think I should be putting some sockets above the cupboard height alongside that wall for surface mounted appliances or powering laptop via extension leads etc. If so, at what height and how many?
I ask only because I don’t want it to look funny and not sure if I’ve seen sockets at this height before. Typical cupboard height is 700mm so base of socket will start at about 750-800mm?
