Hi, this is my fist post. My name is Andy and I've just got the keys to a house I've purchase.
The house is in Huddersfield and is a 2 bed end of terrace house.
I have conflicting information as to when it was built. My mortgage survey says 1920 however my neighbour seems to think 1950.
The bottom half of the front is stone constructed outer with a brick inner. The side is side is fully rendered. I presume this is all brick. The rear of the house is all brick with only the top rendered.
It has a cavity but has had this filled recently (by the previous owners under a government help scheme).
Some of the rendering is cracked and some at the side has cracked and bubbled.
Internally the walls seem to be plastered with black lime underneath.
I will be removing all skirting.
There appears to be some signs of damp (behind where a wardrobe was which coincides with a window which doesn't appear to be sealed properly). I think this maybe the cause but am to investigate further.
I am wondering whether it would be better to completely strip the walls to brick, dry line them or to repair. There's a dado rail which is attached to the black lime. Is it best to remove the black lime in order to re skim over?
The plaster is in OK condition (by that I mean not falling off the walls).
I will try and get some pictures up this evening.
any advice is much appreciated to go hand in hand with advice I will be receiving from a plasterer. I just want to make sure I am doing the right thing. I will be doing most of the work myself.
Many thanks in advance
Andy
Andy
