Plaster over copper pipes.
H
harrisonline
I have chased out a wall with the aim of concealing hot and cold water pipes.
I am not too worried about plaster cracking when the pipes expand as the top half will be covered by a kitchen unit and the lower half tiled.
What I want to know is what to do with regards to covering the copper pipes against the cement or plaster. As I heard I should do this. Someone said to use insulation tape but that sounded a bit naff. Whats the proper way to do it?
Thanks.
9 Mar 2009
Cleveland
Yep, it's up to you.
Plastic pipe's probably easier for ya, but denso tape on copper is just the same. ;)
H
harrisonline
When you say plastic pipe, do you mean to put it over the copper pipe or use it instead of copper pipe? If its the latter. How do you join plastic to the existing copper?
H
harrisonline
Are the joins reliable. I've not had any experience with them! Thanks again.
