I have 30x60 tiles that weight 20.5Kg per square metre, so with adhesive and grout this will breach the recommended limit of 20 for plastered surfaces.
My wall is sand/cement base with a mixture of plaster finishing coat and easifill (ahem). I have scraped off a lot of the most unsound plaster finish layer, but what remains, covering large areas of the wall, is pretty well bonded and tricky to get off.
My question is - for such a breach of the limit, perhaps 10 - 20%, should I persevere and get all the skim coat off? Or could I do more harm than good in terms of damaging the sand/cement layer, in areas where the finish coat seems very well bonded.
Also, if I end up with any small indented areas of 2 - 3mm - whether through over-vigorous finish coat removal, or because we decided to leave alone with just the loose skim taken off... Should I patch the sand/cement indent with something to make it level, or as it is such a thin layer and the existing sand/cement is such a good substrate, am I best leaving it alone for the tiler to let thicker adhesive areas take up the slack?
Picture attached.
In terms of other solutions - I don't have spare width to put in battens and marmox, although at a push scraping off patches of sand/cement and dotting and dabbing the marmox might leave me enough room. Reluctant to go down that route though, makes it all a bit tight.
I have seen mention of "skim and set plaster" supporting 28kg, but only on forums - this makes me wonder whether previous guidelines used to be less stringent, meaning I could get away with it ....
Picture attached.
