Hi guys,
Newbie on this forum.
I am currently trying my first serious DIY project which is to plasterboard the spare bedroom and build a false ceiling using plasterboards.
The room is 5 metres by 3 metres so not huge.
I just have a few queries and would be most grateful for any feedback.
1. Bare brick walls - how clean do they have to be before attempting dot and dab - I have managed to remove all plaster and any loose sand/plaster left with just bits and bats of sand clusters remaining which can be removed with a brush. Is this sufficient?
2. I will purchase the wood to create the stud frame for ceiling, what is the best way to fix the perimeter of the wood to the walls below the original ceiling? Is 2 by 3 (thats the name I was given) wood sufficient for this.
3. Plasterboards - tapered or straight? Which should be used. Also does the plasterboard need to be staggered on the walls? Walls will be approximately 2600mm high taking the false ceiling into equation?
4. Is it advisable to fit the door frame in first and then use that as a guide for aligning the plasterboards around the room.
I won't be touching any electrics as the switches are all fine and will just cut plasterboard around them.
Thanks in advance for any feedback to the many questions I have.
