Wait till the spark has finished wiring & then board the ceilings first. Won’t he also need access to the walls to run & terminate the cables to light switch/socket outlet boxes?
if you happen to have a ceiling joist tight against the wall, this may get swallowed up by the wall plaster thickness, thus leaving you with little material to nail the ceiling boards into.
