Plasterboard repair behind and just above skirting SBR needed?
30 May 2022
If you using foam adhesive to stick plasterboard to a low section of wall do you really need SBR on the wall first? . Really don’t want to seal the wall as I have a breathable lime finish on other side.
Won't the plasterboard reduce the breathability of the lime any way?
Won't the plasterboard reduce the breathability of the lime any way ?
The plasterboard is on the other side and yes I suppose it will but surely coating with SBR before fixing will trap any moisture even more.
Sorry, I don't know the answer. Hopefully someone who does will be a long soon.
No need for SBR if you’re boarding over it
