Hi- our house is only 5 years old, it's all timber construction and on metal stilts(200mm) on concrete pads. The ceiling of the living room is getting progressively worse, think the joints were paper taped and they have all failed, and the screws are visible on some walls and along the joins of the ceiling to the walls...it looks a total mess under certain lighting and looks like it all needs redone. Looking at it I can see on the ceiling the skim on each side of the failed joint, if the paper joint is removed will this need sanded back to the original board too before I re-tape the joints with the adhesive mesh tape?? Otherwise it would be like trying to put tape back on an "upside down channel"(!)- ie take the boards back to a flat surface?.
What can be done about the screw heads? Skim over them or is this an indicator of movement?
The worst 2 rooms are the living room and our bedroom directly above, and I'm wondering given timber construction with no solid floor, and the 12kw multifuel stove in the living room whose flue passes through the bedroom pumps out a fair old heat 7-8 months of the year, is this the cause of the problem and are we wasting our time redoing all the joints etc? The equivalent 2 rooms at the other end of the house are relatively crack free and in good enough order, a few tiny cracks but nothing a bit of compound on a finger wouldn't sort....they don't get anywhere near the fluctuations in temperature or presumably humidity???
Any advice appreciated, got enough to do without adding all this (mess!!) to the list!!!
