Hi, tried to find similar threads but they all seem to be about jointing and filling!
I have some old ceilings with massive cracks and intend to plasterboard over them and then skim myself. The questions I need to answer though are;
1. It is correct I should use square edge boards when skimming over too?
2. It is advisable to leave a small gap of a few mills between each board to get some of the finish in between them (sure I read this as a way to prevent cracking between boards)?
3. Should I tape the gaps with the mesh scrim tape, or paper tape, or none at all?
4. The how too's I have read suggest nogins between joists to fix screws at the board edges between joists. This isn't going to be possible without removing the old lathe and plaster which I would prefer to avoid. Is this really necessary from experience with 12.5mm Boards?
Thanks!
Thanks!
