Plasterer required
7 Aug 2008
Farndon
Hi all,
I am in need of a good plasterer to undertake a small amount of work. I should think the job will be relatively simple, we have a rather old existing loft conversion but unfortunately there is no insulation between the rafters making the room very cold.
It has been suggested that, as it will be far too much upheaval to strip down the whole ceiling, deepen the rafters (50mm airgap needed) and insulate that we should fix insulated plasterboard over the existing ceiling and re-skim. We can afford to loose approximately 40mm headroom and even a small difference would be good as right now when it snows, all the snow melts on the roof.
It would be greatly appreciate it if you can recommend anyone in my area who would be happy to do this.
Thank you and a Merry Christmas
