hi I have been on a plastering course and would like to know what other methods pleople use to do plastering.
do you set beads using plaster or screws?
do you use a darby and if so why and how?
do you use board finnish on boards or multi?
does anyone use carlite any more?
does any one use wood battens as screeds or any other method to level walls?
were do you start to plaster bottom top left or right?
do you do one coat or two and at what thickness?
does anyone use fibres in there mix or lime or any other additives and why?
do you use nails or screws for plaster board?
how many sq meters is a resonable amount for a professional to do in a day?
how do you cut your beads snips or hack saw and are they mitred at the corners or staight?
does anyone use the external tape that has metal strips on it here?http://www.toolstation.com/search.html?searchstr=10867
what type of trowels do you use marshaltown or refina s/steel or carbonsteel?
how do you stop carbon steel rusting?
does anyone have any tips on plastering?
does anyone use other types of plaster (knauf/amourcoat/polished ect)?
what type of sand do you use for rendering and what rtaios?
what do you do about sockets wires coving skirting and acitrave when plactering?
