    Dismiss Notice
Plastic coating to go over paint?
Discussion in 'Decorating and Painting' started by Scramble, 10 Feb 2010.
  1. Scramble
    Scramble
    10 Feb 2010
    13
    Thanks Received:
    Nottinghamshire
    Country:
    I've painted the heads of some copies of my front door keys so that they're recognizable within a large bunch of keys (my local keycutter says they don't have any novelty patterned key in that form of key yet).
    But I suspect that the paint may eventually wear off as keys rub against each other so often. I was wondering whether there was any sort of plasticy laminate-type clear coating that anyone knows of that I could put over the paint to make it stronger and better able to withstand the constant bashing it will get?
  2. Sponsored Links
  3. wallcoatingsbloke
    wallcoatingsbloke
    6 Dec 2005
    57
    Thanks Received:
    2
    Devon
    Country:
    Hi.
    May i suggest using either spray on "Clear lacquer" which is used for cars, to protect and shine the paint after spraying it, you can find it amongst the spray paint in halfords etc, or go to an ART AND CRAFT supplies shop, who should be able to reccomend a clear fixative or sealing spray, normally used for art, to preserve the paint underneath.
    good luck.
  4. LJW61
    LJW61
    1 Mar 2009
    481
    Thanks Received:
    63
    Buckinghamshire
    Country:
    Depends on what type of paint you used to colour them.. Oil-based paint will pickle if you sray it with clear laquer from a can..
  5. Scramble
    Scramble
    10 Feb 2010
    13
    Thanks Received:
    Nottinghamshire
    Country:
    Thanks for the replies.
    The paint I used was Crown's matt emulsion for walls and ceilings.
    For a primer I used International's special metals primer.
  6. LJW61
    LJW61
    1 Mar 2009
    481
    Thanks Received:
    63
    Buckinghamshire
    Country:
    Maybe you could dip them in some polyurethane varnish?
  7. Sponsored Links
  8. Scramble
    Scramble
    10 Feb 2010
    13
    Thanks Received:
    Nottinghamshire
    Country:
    Could be worth a try, but all the polyurethane varnish I've looked at says to use it on wood only.
  9. LJW61
    LJW61
    1 Mar 2009
    481
    Thanks Received:
    63
    Buckinghamshire
    Country:
    Itll dry on anything.. You couldalso say keys shouldnt be painted with emulsion ! :evil: ;)
  10. conny
    conny
    30 Jun 2008
    14,135
    Thanks Received:
    802
    Suffolk
    Country:
    Try some clear nail varnish off the wife/girlfriend.
  11. Scramble
    Scramble
    10 Feb 2010
    13
    Thanks Received:
    Nottinghamshire
    Country:
    Okay, I shall go for either the car lacquer or the polyurethane varnish.
    Only question now is how long should I let the paint dry for? So far I've let it dry for 6 days.
    I did read some stuff that suggests that oil-based paints take a long time to really cure properly (weeks, maybe months) and that putting something like varnish over them will make them wrinkle if they haven't fully dried out, which is one reason I went for emulsion, which is water-based. It's been drying for 6 days now, is that likely to be enough?
    (Not that it really matters, it's just a bit of fun!)
  12. LJW61
    LJW61
    1 Mar 2009
    481
    Thanks Received:
    63
    Buckinghamshire
    Country:
    Emulsion will be fine after just a few hours ;)
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
