Plastic manhole chamber
9 Jun 2014
Yorkshire
i have put new drains around the house. I have used the plastic round chambers.
The base has outlets on both sides (4 at the sides and two in the middle).
Waste comes into the base from 2 points on one side and exits out the middle outlet. All good.
But on the non used side where I have blanks fitted I get a small build up of waste/paper inside these outlets. It’s not a massive problem but I can imagine in the summer in hot weather you will smell this stuff as it is clearing away.
So can I buy anything for these chambers where I can blank these legs off around the main channel area which runs away. So you don’t get any rubbish stuck in the non used outlet small areas
You can get angled blanks to fit into them so it sits flush with the channel.
images
Thanks Madrab, been trying to locate where these are sold but drawing a blank (ho ho) at the mo. Any links ?
