hard to say. i bought a large pair of rothenberg plastic cutters at 25 quid. they even cut up to 42mm waste pipe. . it depends what sizes u need them for and how much use they'll get.
Some big ratchet ones which cut upto 1 1/2" waste pipe
Some rothenberger small red ones
& I've just bought some from screwfix (which i haven't tested yet).
I'm going to need to be cutting Hep every day for a few months, so need them to last, and also need them to be quick and easy. So I'm hoping these screwfix ones should do the job
You will be cutting plastic, they will last long enough.
Unless you have the misfortune to work on site and some ***** "borrows" your "cutters" to shorten a bit of cable.
builders
