Can anyone advise on the suitability of plastic pipes for connecting radiators in a central heating system?
I had a new stailess steel towel rail rad fitted 2 years ago. The rad was fitted using 5mm plastic pipes. It worked fine until last week. Now, while rest of rads are hot, the new one only gets warm. The entry valve however is hot, there is no air in the rad and when the bleed valves are opened, clean warm water sprays out. The system has Fernox MB1 added.
'The gas man cometh' is suggesting that some plastic pipes allow air to enter the system which in turn promotes the formation of rust...... the rust particles and the small bore pipe have, in this case, caused a blockage requiring the system to be flushed.
Can such small lengths of plastic pipe, i.e. less than 1/2 meter, have such a major effect on the formation of rust in a system protected with inhibitor?
