Hi
Got a bit of a leak from one of the feed pipes for our boiler. It's grey plastic piping which has a stoptap on it, all brass fittings. The leak appears to be coming from the nuts joining the tap to the plastic pipe - no obvious hole etc.
Not worked with plastic pipe before - do I need to use plastic fittings rather than brass? Or might a bit of magic PTFE sort it? ta!
