plastic rain water pipes changed from cast iron
19 May 2005
Cheshire
Hi i have been asked to change cast iron down pipe/rainwater pipe to plastic as it is leaking but the guttering is staying as cast iron can this be done?
or do you have to change guttering to plastic if it can be done is there are a special connection to put plastic down pipe into cast iron guttering
thanks for any advice
plastic downpipe will go over c/i outlet........(.In fact I`ve seen some plastic that is made to look like cast iron :!: )..as a young plumb you should be made to fix downpipes to concrete colums without an sds drill :shock: like I had to on a block of flats in Hastings :shock: 1972.....so sds had`nt been invented :lol: ..I`ll never forget that ******* job :evil:
