Plasticiser mix ratio
5 Apr 2011
Hampshire
Hi guys, not sure if this is in the right section so here goes, I’m about to lay the ridge on my roof, the instructions on the plasticiser bottle are referring to using 25kg of cement but there’s no way I’m going to use that much cement on a 5 meter ridge!!! Is there another way to measure this ratio? ( please don’t say use a dry ridge as that’s what I’m removing)…
Do the maths
You can work it out by weight using scales or measure volume.
It's not critical you get it correct.
Easiest way is to scale it by weight. Put a level bucket of cement on bathroom scales (an empty bucket is light enough to ignore, or weigh it first and subtract), then:
dose = bottle dose x (cement weight / 25)
So if the bottle says 50 ml per 25 kg and your bucket of cement weighs 15 kg, you need about 30 ml. A medicine cup or a syringe from the chemist makes small doses easy.
For a 5 m ridge you'll probably only mix one or two batches of about 1 bucket cement to 3 or 4 buckets sand, so mix one batch, see how it handles, and keep the same dose for the rest so the colour and strength stay consistent. Err on the low side rather than overdosing. Too much plasticiser entrains extra air and weakens the mortar, which is the last thing you want on a ridge.
