I've just opened my Grant Euroflame (50/70 I think) boiler up to have a look see inside, because it's been cutting out a lot, and was shocked to find some of the interior plates have been devastated by extreme heat.
Well, two of them have. There are several plates in there but the two nearest the burner have suffered the worst, there wasn't much left of the bottom most plate, it has almost completely disintegrated... The one above it had started to melt and warped badly, the one above that was beginning to warp.
This is, obviously, due to absolutely extreme heat inside the boiler, what I'd like to know is if it was due to me having the air intake increased or because I've lowered it.
What I mean is, a couple of weeks ago, I put the burner air intake setting around the 7 mark, because of building I was doing in the loft around the flu, whenever the boiler was on heating the water (luckily not needed it for rads lately), the smoke (not a lot but enough to be a pain) and the odur was really off-putting for me while I was working. Of course turning it off wouldn't last long one of the resident resource hoggers would moan at me and demand it turned back on, or face pain of death.
So I increased the air intake temporarily so we still had heating but it just didn't smoke and stink as much as it normally did and gas me while I was working. This seemingly worked, but the boiler didn't 'alf roar. I knew I couldn't leave it like that for long but I did anyway, been like it ever since. Only just turned it down the other day back to its normal setting of around 5. However it started to cut out, which it never used to do. I kept pressing the reset button, it'd go for a while then eventually cut out again.
I figured having it on such a high setting may have cause some crap to get dislodged from the flu and build up inside it so I took it apart to have a look inside and found the above devastation.
So it's evident my dicking around with the air intake has complete buggered the boiler plates but luckily it doesn't seem to have melted anything else. I'm surprised actually the water jacket didn't explode or something.
The thing is, what I need to know really is, if having it at a high air intake setting was what melted the plates, or if it's because I've turned it down too low? My initial thought is having it so high caused the plates to melt, and when I set it down low the resulting debris and obstruction in the way of jet was causing it to cut out because it was no longer blasting air in as much as it was and unable to keep the flame going in amongst the buildup of debris.
