Please can someone help identify my shower??
pjt
20 Jan 2010
Hi please can someone help identify my shower, the pipe is leaking from the main unit (where it connects to the main unit) and is spraying everywhere and needs replacing
My second question is, is there a part to replace this and is it easy replacable?
Many thanks
Phil
[/img]
Almost any shower hose will fit. You will get one from your local plumbers merchants or DIY store. The size is 1/2 inch BSPT and you will need to measure the length of the old one as several lengths are available.
I forgot to mention - unscrew the hose from the shower and check the rubber washer is in place and not perished. Theses are available as seperate items.
Steve
