Reading a fair amount lately re these EV granny charging cable plugtops/sockets etc going on fire and wondered how much heat is generated in the fuse itself, not a lot if my tests are to be believed, tests were done on a DC circuit with a battery so maybe more heat generated under AC conditions?.
My M.meter measured 10A (DC) through a mini air compressor and a fuse volt drop (measured between the fuse caps) of 0.046VDC on the 0-2V scale and 50 on the 0-200k scale so I assume 0.05VDC drop through the 13A fuse with a 10A load, this equates to a fuse resistance of only, 0.05/10, 0.005 ohms and a heat loss of 0.05*10, 0.5 watts?? seems very very low?. Google/AI……state that the resistance of a typical BS1362 13A fuse is 4mOhm.
What is 4mOhms in ohms??
