I'm thinking of installing a point of use mini hot water cylinder into my laundry room.
Something like this: https://www.plumbnation.co.uk/site/...-sink-15l-3kw-electric-unvented-water-heater/
My question is, can I connect an unvented mini cylinder to the water supply from my loft header tank, not the water mains feed. Reason being we don't have mains. (catchment tank) To do this, maybe I cannot connect the pressure reducing valve?
However, I know you get vented ones but have to use a specific venting tap which are pretty sub standard in looks. If I cant use an unvented cylinder and get a vented mini one with vented tap could i hook up 2 taps from it, one for kitchen (standard tap) and one for laundry room (venting tap) but only have one use the venting tap or do they both need to be vented ?
Cheers
Cheers
