I recently redesigned my bathroom, I removed a radiatior from a Combi Boiler fed 10mm microbore system, I removed the piping back from the room up the wall & into the loft where I linked it through to by pass the previous radiator.
I now would like to replace it with a ladder type vertical towel radiator of the same capacity. Has the feed in & out to/from the new radiator got to be from below & under neath the rad or can I simply feed in from above rather than re-route the piping back down through the ceiling to the floor & then into the rad from below at skirting board level??????
