Hi i was wondering if anyone could help me, i have an old back boiler that still works fine it is a open vented system with the tank in the loft, the water is set at correct leval when cold, i have a problem getting the rads to work tried a new pump had the rads off about 5 times hit them and washed them but to no avail. i took the floors up in the bed rooms and it seems the 22mm pipe is the main flo and return with the 4 rads branching of in 15mm, all except a new rad that was fitted about 10 yrs ago down stairs but not on the same run as all the others seems to have its own 22mm under bedroom floor comes down in 15mm to the rad and back up, it will heat up on its own but soon as you put the others on it goes cold.
i can get heat with all downstairs off and vise versa but not all together.
also i have been told that changing the pump to the flo and not the return might be better, any help on the subject would be most greatly recieved
