I've recently done a mock test for a plumbing exam and wasnt happy with some of the answers given by the tutors, can any of you more knowledgeable plumbers give me your opinions on the following:
1.what is required soundness test pressure for hot water pipework which is normally subject to static head pressure of 6 metres?
a.1.2 bar b.0.9 bar c.0.6 bar
which of the following can be fitted to a hot water storage cylinder to provide protection against type 1 pitting corrosion?
a. pressure reducing valve b. magnetic conditioner c.sacrificial anode
what backflow protection device should be fitted to mixer tap fed with from cold mains that permits mixing of hot and cold water in valve body
a.double check valve b.single check valve
during soundness testing on an open vented hot water system ?
a. cold feed gate valve should be opened b.open vent pipe should be capped c.two taps should be opened
i went with b. c. b. and b. but was given other answers,so confused
