plumbing in sink - quick question
30 May 2005
Hi
I am plumbing in a sink unit next to our bath - the 40mm waste pipework for the bath is a couple of inches above the floor level and this height can't be easily altered. This means the pipe runs out of the bath panel along the wall - the problem is that the sink unit has drawers and I don't really want to cut the back to accommodate the pipe.
Question - can I drop the pipe under the floor behind the bath and then back up through the centre of the unit (about 300mm under the floor). This would create a "trap" but the sink is high so the water should flow okay. Any downsides?
I hope this makes sense?
cheers
Tim
well you could but you would need to connect the pipe to the waste fitting without a trap - you should use a Hep V O waste valve - trust me , I`m a Proper Plumber :wink: . Also consider running the pipe in the wall where the edge of the unit sits . OK you`d cut a 40mm deep chase but it need only be say 75 mm long - obviously check for wires etc.
