plumbing
4 Aug 2008
Belfast
hi could someone please tell me, does it matter what side the flow should go in on a rad
thankyou :oops:
Depends on the rad, and as long as you are fitting new rads then this shouldn't be a problem becasue they come with instructions on just this point. Some rads are particular about flow direction due to internal baffles and they are generally marked. A lot of rads it makes no difference at all.
thankyou . i have another question :D we have small old pipes i think they are 10mm or below then my partner changed some rads. he put 15mm onto the rads and reduced it to the 10mm which fits on the mains feed should we change it all to 15mm
hi jamie thanks for your reply my rads are working but the hot water has stopped working when i balanced the rads
