Ideal classic lxff & fanned flue gas bolier problems, he
29 Jul 2009
Yorkshire
Hi, could some 1 help me pleAse, I draned my system to change a rad to a towel rail, all went well filled back up, bled thes rads, when to turn bolier on and it won't kick In, tryed Again this morning and it kicks in for about a min then goes out again? Any ideas? Thankyou
Got an airlock in the pipes, take a look for a bleed on the pipework around the diverter valve / cylinder somewhere.
Thanks, this might sound a bit daft but where abouts would that normaly be? I'm a bit of a novice with plumbing, electric is more my thing :) also I've been Reading that I should bleed the pumps, could this also be something to do with it, thanks for your help
dan
DRain it down again, making sure you open all vents (including any near the cylinder) and make sure that the Zone valves are fixed open! Then re-fill it and see if it helps.
