Hello, as the headline suggests, I'm having probs with the grass on my outer verge.
Anytime the rain comes it goes as soft as putty and even when you walk on it you get a soggy footprint and dont even start on the tyre tracks that has wrecked the verge.
What I want to know is can you get a certain type of grass that looks good but will somehow either NOT soak water into the soil below (dries up on surface) or DOES soak water into the soil but disperses quickly. Are there any techniques I can use to solve the problem?
One of the main factors is that below the 6 inches of soil is concrete!!! So the water cant drain down through the soil, which means it sits in the soil making it very damp.
Any suggestions would be a great help. Thanks
MM
MM
